Slides as Negative, is it possible?
Joenail
Joe
Been reading up about b&w conversions from Ektar, ie printed in a black & white darkroom, but is it possible to dev a colour transparency as a black & white negative (much like cross processing), or would the difference between C41 & black & white chemistry be too much & leave the film blank?
-J
This might be of help :) I know the title is C-41 but they do have info on souping slide films too!
http://www.flickr.com/groups/c41inbw/
I don't know much about developing colour film in black & white chemicals but I quite often print colour negatives as black & white in the darkroom (either because I intended the shot to be black & white but only had colour film, or because I want a really nice print to send to someone that I've made myself and my university won't let me in the colour darkrooms because they're tight haha).
Hi,
Technically it could be possible as the first step of the E-6 process (first developer) is a phenidone type B&W developer which forms a silver negative of each layer of the film. Subsequently theres a water stop bath, a reversal bath and then a colour developer which forms dyes in each layer from colour couplers. This leaves a black and white image on top of a colour one, the B&W is then bleached away to leave the colour and fixed. You can do the same with C-41 films as the two processes are extremely similar with (hence why you can cross process them) but the C-41 process lacks the reversal bath.
All that you would need to do is only do the first (1st dev) and second step (stop wash) and then the fixing to get a negative B&W image, essentially the same as normal B&W processing. All colour processes involve creating a B&W image and then bleaching it away when the colour image is formed hence why you can 'bleach bypass' negative film (it doesn't work with E-6 though as your left with a negative on top of a positive) where the bleach step is skipped or reduced leaving the B&W layer, creating deep blacks and contrast with desaturated colours.
