Skylight 1A filters
martin.benson
In the olden days I always used a Skylight 1A filter on my 35mm Olympus OM lenses - a bit of cheap, basic lens protection.
Is this solution considered ok for digital lenses (specifically Olympus E-series) or is there a more up to date recommendation please?
Martin
UV or Skylight 1a do just the same as basic lens protection, I have them on all of my lenses, but you will get the other side of the argument....Just "Old School" I guess!
As long as it's from a reliable manufacturer, it'll be fine.
In bench-tests in a lab or when shooting at night with point light-sources visible in the frame then a filter should be removed temporarily, but for general use, keep it on. Saves wear and tear.
Put it this way:
I'm currently selling a lens that's 10 years old and which has had a Nikon UV filter on since it was new.
That filter has come off that lens twice to my certain knowledge.
So I reckon that front element has been touched maybe three times in its entire life.
There are (apparently) visible differences from cheap filters as opposed to expensive ones but not all the expensive ones are the best. I found a pretty rigorous test a while ago in which Hoya Pro 1 filters came at or near the top. I have since bought several clear protectors of that brand and have no complaints so far, although the multicoating can be difficult to keep totally smear-free. Be aware that Kenko also do Pro 1 filters - they are not the same.
