1. Good stuff
2. The histogram shows the distribution of light and dark tones throughout the image and gives an indication of how much of each you have. If the histogram is all bunched up at the right hand side then your shot is overexposed. It is a good thing for it to touch the right hand edge but if there is a big spike on the extreme edge, that means you've overexposed a lot of pixels. There are lots of guides to histograms on the net. A Google will find plenty. Here's one good example....
http://www.cambridgeincolour.com/tutorials/histograms1.htm
About half way down the page there are sample pictures and their respective histograms, indicating what clipped highlights look like in an overexposed image.
I don't know whether the 10D has the blinking warning or not. On the 30D and 40D I think you have to enable the feature - it is not enabled by default. EDIT : Yes it does. See this page -
http://www.dpreview.com/reviews/CanonEOS10D/page9.asp.
3. With a bit more experience, this is a fairly easy scene to meter and expose correctly - especially if you use your histogram to check your exposure. For difficult scenes, or if you're not sure what you're doing, at least AEB will enable you to go home with the shot in the bag. Your approach depends on what is more important - getting the shot, or learning how to get the shot. AEB can also be a handy way to try to learn more about how your camera's metering works, and maybe why "the meter got it wrong".
4. That's it exactly
But it's my guess +2 EC will not be enough. You'll ideally need to switch to manual exposure so that you can force more than 2 stops brighter than the metered reading.
5. I don't know the 10D - I have a 30D and 40D. The manual should tell you all. EDIT : OK, I just checked the DPReview website to look for an example of the blinking highlight warning, and saw an image of the back of the 10D. There is a thumbwheel on the back, the same as the 30D and 40D. The power switch has two "On" positions. If you turn the camera "On" to the second "On" position - i.e. all the way "On" - this will enable the thumbwheel to function. In an AE mode, half press the shutter, so that the camera becomes operational, and then rotate the thumbwheel while looking through the viewfinder. You should see the meter needle moving back and forth. The thumbwheel is controlling your exposure compensation. Centre the needle and then set the "On" switch back to the first "On" position. That will prevent the thumbwheel operating and thus prevent any accidental adjustments to EC.
If you do want to change your EC again then turn the power switch to the second "On" position to re-enable the thumbwheel and make your adjustment.
6. Sorry, my mistake, I saw UV
filter, and your comment about the
angle of the sun, and my mind just invented CPL instead of UV. When you shoot with a CPL filter, and the sun at 90 degrees, you can twist the filter to darken skies and get deep, rich, saturated colours in plant life (and other things). A CPL would probably have done you a favour for this shot, although normally it is effective at darkening blue skies. I'm not sure it would do so well for clouds, but it should enrich the greens and yellows in the plants.
