Sigma 15mm f2.8 fisheye
doublem1
Matt
Bought one of these used recently. Immaculate condition, hardly looks used. But the lens cap is really bugging me, it just slide off so easily. Is this a common issue with this lens?
If it is a cap that pushes over the lens hood I have a solution as I had a similar problem with my Zeiss 15mm.
Get hold of a roll of Gorilla tape (I tried other tape but the adhesive wasn't strong enough) which you can get for under £10 on EBay. Cut a piece about 2cm x 2cm and stick it near the inner edge of the cap. That will fix the problem. You may need 2 small pieces in which case stick them opposite each other.
Andy
Andy
Yes it's one that slides on. This sounds like a good idea actually. I will try it out. Thank you.
Alternatively... Use black electrical tape, and stick a strip of it all around the edge of the cap, folded over the edge so that it's half inside and half outside.
