hey, dont know if this is in the right place or not.
looking for info on shutter speeds/use's?? and ISO levels??
whats the ideal start settings(mostly for MX pics) for bright/dull/rainy days?
any info would be ideal?
cheers![]()
RDH that link hurt my head - might have to read it when i am more awake to get what it means!
What you will need to do though is to understand what shutter speed, aperture and ISO do and how the three relate to each other. I could write a pile of words on it, and no doubt someone else will in a minute, but its quite simple when the penny drops - honest!!!
The shutter speed tells you how long the shutter is open for (the longer it's open, the brighter the image will be, because more light hits the sensor). 1/200th is relatively fast, 1/3 quite slow.
ISO tells you how sensitive the sensor is to light. Generally goes from 100 to 1600 or more. The higher you go, the brighter the image will be, but the more 'noise' or grain a photo will have. (ISO 100/200 will generally give no perceptible noise on a DSLR, whereas even the best cameras show signs of it once they get to 1600/3200)
The aperture, or opening, can be adjusted to let in more or less light. The smaller the F-number, the wider the aperture. F/1.8 is very wide open and lets in lots of light, while F/22 is more closed and lets in very little light. Furthermore, a wide aperture gives a narrow 'depth of field' and so background blur, ideal for isolating a tiger from the expanse of safari park behind him.
(If a lens is described as being "f/2", then that is the maximum aperture.)
Once you've understood that, it's just a case of balancing the three to get the effect you want. If you want to use a fast shutter speed to freeze the motion of a speeding car, then you should use a wider aperture and/or higher ISO.
If you want to get the fluid motion of a river and use a slow shutter speed, set the ISO down and close the aperture a little. F/16, ISO 100 and 2 second shutter speed might get you a nice effect. (Using a tripod of course to eliminate camera shake!)
Hope that helps. It's hard to tell how much you know already!
Yeah, that would be me![]()
ISO tells you how sensitive the sensor is to light. The higher you go, the brighter the image will be,
it would have explained things very much more quickly and easily for me when I started!These statements are very misleading and don't actually address the question asked
Well done for the words CT.... of course a proper tutorial will also include not only the relationship between the three variables and how that effects exposure, but also discussion about how each of them also brings different effects into play (action freezing/blur, dof and grain)...
To be honest, there are enough books out there, people should really go read.... forums are good for specific questions but wider questions and background knowledge are best learnt from the experts in considered published writing (not that I am knocking you CT, you do know your stuff!) rather than a hurried forum posting...
