What you've done there Nick is created yourself a Raw workflow, but using JPEGs as close as you can create to a Raw file.
Since the workflow involves the use of JPEG files and does not involve the use of raw files, I find it more logical to describe it as a JPEG workflow than a raw workflow.
I believe that to use the word raw to describe a process involving the manipulation of source files with only 3 x 8 bits per pixel risks misleading or confusing less experienced people.
My workflow may be similar to the workflow some people use for raw, but I could equally as well say that some people's raw workflow is similar to my JPEG workflow, but this would not cause me to describe their workflow as a JPEG workflow. I believe the argument is symmetric.
What I believe I have done (and continue to develop) is to create a JPEG workflow that gets me the best results I currently can with my chosen (JPEG) source material.
Despite your assumptions there is more to be had from a Raw file,
This implies that I have assumed that there is no more to be had from a raw file than a JPEG file, but I wrote "As noted in many other contributions here, raw files contain more information than JPEGs and this additional information can enable some operations which are not possible with JPEGs." So to which assumptions are you referring?
but if your JPEG output is 'good enough' that's all that's important (to you).
In common usage the term "good enough" often carries an unspoken negative component, and I can't help wondering whether your use of term (especially in its quoted form) is intended to carry a negative connotation of some sort. You see, in relation to good enough and also the (to you) qualification which also might be interpreted as carrying a negative subtext, I know how a number of other people (including some who only, mainly or sometimes use raw, on cameras up to and including full frame) have reacted to my JPEG-originated images; terms such as (all used on this site) impressive, excellent, superb, splendid, awesome, amazing, brilliant, professional, fab, pin sharp and so much detail or Look very Real without being overly Manipulated suggest to me that I am not the only one who thinks that JPEG-oriented images can indeed be good enough, in an unqualified positive sense.
Buts lets go back to the pivotal point that developed your workflow;
I tried using raw my current (Panasonic G3) camera took control away from me periodically and this destroyed the flow of my picture-taking and also caused loss of good opportunities, which are often time critical
I had to read that a couple of times, but you appear to be saying that your camera buffer fills too quickly?
I believe that is what is going on, and the (assuming it is a buffer issue) "full-buffer/you'll have to wait" status lasts too long for my purposes.
you've created a workflow that gives you 90% of what a Raw workflow would give,
No need to quibble over exact numbers here I agree with the sentiment. In the same spirit, a raw workflow might give me 90% of what my current workflow gives me. That is, neither workflow would give me all that I would ideally like. With one I lose shots because of timing issues, and with the other I lose processing opportunities because of the lack of bits. (Roughly speaking.)
but to have to do that because of your cameras slow processor is a bit of a shame.
Perhaps you could help me here and point me to a camera which can take bursts of unlimited numbers of raw images without any interruption to operator controlled activities?
Yours isn't JPEG because its as capable,
This is true. However, if one were to draw the implication from your mentioning this that I have suggested otherwise, then one would be mistaken.
it's JPEG because your camera is too slow for you.
The slowness of the camera when using raw is a sufficient condition at present for my use of JPEG, but I do not conclude from this that I would use raw were it not for the loss of capture control that using raw causes; it is an open question. While there would be obvious benefits in terms of processing options, there would be disbenefits too stemming from the additional time required for data management of my quite large datasets for example it already takes a significant amount of time to load 1,000+ images from my camera to my PC and then make short term security copies of all of them. And if I used RAW + JPEG rather than just RAW there would be additional data management complexity too, as well as an additional increase in timescales for bulk data management operations.
If and when I have a camera that allows me to use raw without disrupting my capture workflow I shall try using raw and see where the balance of benefit and disbenefit lies, and then decide whether to add raw to my kitbag and if so decide the extent and nature of its role. As with many aspects of photography, there are tradeoffs and knock-on effects to consider, and whilst I am greatly in favour of learning about concepts, methods, options and recommended practices, for me it is the practical operational issues and the characteristics of the outputs that are the final arbiters of what mix of options I adopt.
