But if you've got a decent JPEG, there's no need to go anywhere near any post processing at all - it's straight to output. That's where the time saving is.
The camera doesn't do any interpretation, it only does eactly what you tell it with the pre-set parameters in Picture Styles with adjustments for sharpness, contrast, saturation and colour tone. With that lot, you have hundreds of different processing permutations. If you use auto white balance, the camera will take a guess at that, just as it will with fully auto exposure control, but you can set both of these manually if you know what you're doing and don't trust the camera. And it's sometimes best that you do, regardless of Raw or JPEG - you cannot afford to be too far out with either.
If all you ever do in post processing is basic tweaking of Picture Styles, then if you know what you want before the picture is taken the camera will do it all for you, and the result will be identical in every respect. There is no improvement in quality just by doing it manually in post; there is only a benefit if you change things in post that the camera is not programmed to do.
Sorry if you know this, it's just not clear from you post![]()
Yes, I do know all that, but I still get better results when I produce the jpeg from the raw file rather than when the camera produces it, which ever presets I put into the camera. There is far more room for maneuver that way.
So it is still an interpretation by the camera. If I set the contrast, for example, in canera there are only a small number of settings I can choose. If I set the contrast in the raw file I have a much better fine tuning option. For example,for argument's sake, I can set the contrast in camera from -3 to +3 whereas in the raw converter I can set from -50 to +100. It takes me approximately 1 minute to do what I need to do in ACR, a short time to produce what I think is a "decent" jpeg.
I was just pointing out the massive range available! What I meant was that instead of just three settings either side of zero, there are more options in the raw conversion. As for "interpretation", well maybe I'm not using the correct word there but I'm sure you know what I meant.
