paulminus273
- paul
I think I posted this on the wrong forum before anyway
I have use a couple of the cheap flash guns off camera with rf602 triggers but now an old friend has given me 2 SB900s . I would like to try out the cls and I know that I can use the pop up flash on the d90 to control the sb900s but
A in bright sun IR is not that reliable
B on camera flash is not that desirable to me
So in order to use cls I could use pw radio triggers, expensive or I could use an Nikon cable to control one much cheaper.
The question is can I get a cable system to control both
Thanks for any help you may be ale to give
), but for it to work with any sense of reliability in sunshine the trigger (in your case the D90 onboard) and the receiver ports on the SB900s need to be in the shade.
