SB900 Problem "HELP"
Craig2008
Craig Thomas
Hi All,
I have posed this in the hardware section awell.
I have problem with my SB900 tonight shooting away and everything stops, can fire the camera so i take the flash off and the camera seems to be fine. The flash however, now has the Red ready-light continuously flashing, doesn't matter if the unit is on or switched off it still flashes only stops when the batteries are taken out.
help and guidance much appreciated
nope i wasn't really pushing it at all, nearly 2 hours later and the light is still flashing even when the flash is switched off! and cant do anything with the flash
Sounds like one for Nikon.
If you have NPS call them and ask advice. But it sounds like you'll need to send it in.
turn everything off and try a new set of batteries
