discoman
- John
Right if you have seen my other thread regarding the battery compartment door, then you will know I have been having problems with turning the sb600 on.
I now know what the problem is and it is the battery compartment door that is loose on it hinges.
I have try to tape it down and no luck, so the next step from here, is taking it to a shop to see if I can get a replacement door.
I live in mid Kent nr Maidstone, so does anyone know of a shop local to me that may be able to do a repair?
