Running virtual machines makes you vulnerable
ancient_mariner
Moderator
Toni
If I read this correctly, running (presumably Windows?) in a virtual machine actually made your system vulnerable. IIRC there were a couple of people who were running virtual machines in order to be more secure against viruses/malware.
Just a heads-up.
i cant say i'm overly surprised, im more surprised that its taken this long for an exploit to surface.
using a VM as your day to day machine personally i don't think is of any benefit for security. i think people get a bit confused by VM sandboxes but those are very disposable VMs that are intended to be trashed via testing rather than being hooked up to your daily data.
Hyper-v runs on top of the windows operating system. Other virtual infrastructures don't work this way.
A VM is still a machine with the same rules that affect a physical.
If you limp on the AV or malware protection then its just as easy to infect.
I use a Win 10 VM on Hyper V as my secure PC for banking and that's all.
It has AV and Malwarebytes and Rapport site protection and that's all it does.
I don't intend trashing it every few weeks as some have suggested, it juust means I can keep my more sensitive internet stuff on a separate PC.
I use VirtualBox (it rocks) for WIn XP on development stuff, have 60GB SQL Server Databases attached as separate files - been using it for about 10 years and it works amazingly. Very handy to back up - very handy to restore if my machine goes t1ts up. Wouldnt run a main machine on there though.
Its also good to try out all the other OS's such as Mint, AmigaOS and IOS. I have a Win10 development machine set up on there too. Of course, I have bitdefender with licences on all of the machines including the host PC so feel pretty safe from any malware tbh and never have had any issues.
FWIW i wasnt suggesting you should intentionally trash your VM regularly. only that VM sandboxes were originally by design intended for intensive testing where rolling back to a snapshot is much quicker than reinstalling an OS for example.
Oh I wasn't suggesting you did, I just remember a few anarchists a while ago suggesting that was the way to go.
VMs for me work very well because you can shut them down copy the files and make them portable, I also use a VM for more risky internet such as torrents and again that's all that gets used for. I work all day in a virtual environment so it is easy to get on with. Also having these machines virtual means I can remote access very easy.
windows is vulnerable full stop, unless you cripple it within an inch of its life.
It's patch Tuesday (2nd Tuesday of every month) and Microsoft are shipping out a bunch of fixes, including one which fixes a vulnerability in Hyper-V that allows a VM to access & execute code in the Hyper-V host server.
I used to manage a virtual server environment, and I use VMs under Windows 10 Pro at home. You have to treat the security of a VM as seriously as you would any physical machine.
I run Win 7 64 bit on a host machine with various VMs running both XP (SP3) and Win 7 32 bit and all my surfing is done within them.
Both OSs have had the updates turned off since they were installed.
I use Avast free but just for files since the web checking makes it too slow.
I also use a VPN which blocks dodgy websites.
Nothing of any value is installed on any of my PCs, everything is backed up to external HDDs which are never left plugged in.
I run a weekly scan using MalwareBytes Premium which never shows up anything.
I also use full disk encryption using TrueCrypt in case anything should ever happen to it; then no one can even get onto it - good luck trying to get past the 64 bit password!
I feel quite secure even without the so called security updates..
