Not boring or simple, I think its very clever and shows great technique, I really like it.
Fits the Theme to perfection. Simple ideas work better than complicated ones.
Pete
Dark
Very good, I like the 3 bright lines and their position in the frame (photo). It's really quite imaginative.
That's a really cool shot Stan nice work. I like that the vertical line is not central and the angles work well. The only change I would make is that there is a fuzzy white patch underneath the line of light to the far right of the shot that I might have tried to edit out but that's just me nit picking, I really do love the shot
I love a bit of minimalism and that works a treat![]()
Really strong image for the theme, very good Stan, I like that a lot
Splash by Stan, on FlickrBit of a lemon but still nice to see and good on you for having a go!![]()
Nice idea for splash Stan and good for you for trying to get a shot like this. I especially like the movement in the water. As others have said it is a dark which I'm sure you could fix worth a bit of tweaking
Always good to try something new, even if it doesn't come off exactly as you want it to (see my dark shot recently).
I don't mind the lack of really sharp focus, it give it movement and it's a cool thing to try. Far more adventurous than I was for this theme.
He He
Stan
Splash - I like that. I take it you used a fishtank so that may have made the image a bit softer with its air/glass & glass/water interfaces. Did you use a trigger or pot luck to fire the shutter.
Pete
I like the shot and it is a great idea, spot on theme and so nice to see experimentation in the 52.
Pull is a very well taken image Stan, the dark BG really sets it of well.
It’s a well thought out shot but I have to point out the obvious it’s floating in space, sorry to mention it
Nicely put together, liking the colours and the black background.
As Allan says, it is a bit floaty, but then, pegs do tend to float in the air when attached to a line.
I was just thinking you had done something similar, reminiscent of some of @d00d 's peg photos too. Nicely staged with a good black background but it does look a bit floaty to me.
