RF 602 questions
  • Thread starter Thread starter Deleted member 27472
  • Start date Start date
D
Guest
First off, how does the transmitter work? Does it sit on the camera hot shoe? If so, I take it you can't then use a camera mounted flash?
What I would like to do is use my 550ex camera mounted and use 2x 420ez remotely.
Being thick, will this need a 1 tran, 2 rec or 3 rec?
Also, how does the wireless shutter work, will this need another trans?
It sits on the hotshoe but if you want to use a flash on the hotshoe, U need 1tx connected to camera via pc sync, then 2receivers for the 2 flashes.
