Restore to previous time on W10?
madmardle
Ken
In the past if I have cocked something up on my PC, both on XP and Vista, I have managed to get myself out of trouble by reverting or restoring to an earlier time. I've now done something on my tablet to make it not run properly and I can't fathom out how to restore to a previous time, as per the title, the tablet runs Windows 10. Anyone able to help me please? As you have probably guessed I am not particularly computer literate.
This option takes your PC back to an earlier point in time, called a system restore point. Restore points are generated when you install a new app, driver, or Windows update, and when you create a restore point manually. Restoring won’t affect your personal files, but it will remove apps, drivers, and updates installed after the restore point was made.
  1. Right-click (or press and hold) the Start button, and then select Control Panel.
  2. Search Control Panel for Recovery.
  3. Select Recovery > Open System Restore > Next.
  4. Choose the restore point related to the problematic app, driver, or update, and then select Next > Finish.
Thank you Gramps, problem now resolved at least regarding system restore.
