The23rdman
- Dean
- No
As above. I'm looking at something for home use on a budget. I know I'll probably be upgrading in the future, but right now it has to simply suffice for paper.
I thought there was an issue with a couple of weak components in those Chinese knockoffs? But they can be sorted with a bit of DIY magic. I could be making all of it up...
That's a good idea.Roll of paper?
I got some of this http://www.screwfix.com/p/solvent-weld-waste-pipe-40mm-x-3m-white/44310 - drilled holes in it and had it across light stands. Would be easy to knock up wall brackets.
That's a good idea.![]()
What I suggested was plastic not aluminium, it's not a question of that bending its a question of the internal roll roll bending. If you get pipe that's as close as possible to the inside diameter of your roll and the roll supports its own weight, then the bend of the internal pipe won't matter.I'm considering using vinyl now as more people are asking for family studio shoots. I have room for a 2.72m wide roll, but I'm unsure whether the aluminium @WelshNoob suggested is strong enough to prevent bowing.
The vinyl I'll be using if I go this way comes on aluminium so the problem should be solved now. I'm considering going with my gut and not shooting at home at all like this. It's such a ball ache spending an hour moving furniture in and out.What I suggested was plastic not aluminium, it's not a question of that bending its a question of the internal roll roll bending. If you get pipe that's as close as possible to the inside diameter of your roll and the roll supports its own weight, then the bend of the internal pipe won't matter.
