I bought one of these adaptor kits a while back and it's helped me out many times, it's easy to connect ide or sata hard drives to your pc and salvage data.
I also have/use an adapter like above as it saves opening the machine to connect up a drive. Laptop IDE drives don't fit straight into a desktop but if your drive is a SATA then it uses the same cables as a desktop so you can fit it direct (assuming you have a spare power/data cable available) to save time/cost of getting an adapter.
