You don't say which camera it's for but my Nikon uses a micro USB sized cable that's not compatible with micro USB. It's more square but the cable that comes with the camera could be lengthened by using an extension. I bought the wireless module to use instead of tethering.
that'l be mini usb the type before micro usb became popular
It's about the same size as the mini USB but it's a bit more square. Nikon's part number is E6.
Sorry to high jack, but can anyone recommend a decent USB to micro USB or mirco USB mains charger. I use a tablet a lot and keep killing the micro end, they get really loose. I said USB to micro USB because we have a couple of USB mains adaptors. Does the advice above apply?? Thanks
I'm on holiday at the moment and don't have the D80 to hand but you're right, it does use the mini USB. The D7100 is what I have with me and uses the E6 connector but as I said above I went for the wireless adaptor because I just know I'd trip over the cable and drag the camera off the tripod, however those orange cables look a good high visibility option albeit quite pricey.from what i can gather mini usb is fully compatible with the D80 as it is with a lot of canon and other manufactures
https://www.tethertools.com/plugging-in/usb-compatibilty/ scroll down for mini usb
it looks like nikon have the e6 8 pin lead to do with video / audio is that what socket is on the D80 ?
No it won't.that'l be mini usb the type before micro usb became popular
Not at USB 2 and 3 speeds. It's acting as a transmission line not a wire.It's just four cores with an overall shield. Any with that configuration will work equally well.
Steve.
No it won't.
USB, mini USB and micro USB both have type A and type B plugs.
