PS Action Experts...
Liam
Hi,
I am trying to make a simple action which is able to..
Resize image - save image in a new folder - close image
The problem is that I am doing a batch action on a series of folders (most of my images) but some of the images are called the same thing (e.g IMG_01..)
So the action saves over half of the images, is there a way to stop this happening? Such as numbering them 1,2,3.... as it goes?
Thanks for any help :thumbs:
i have something similar, but all my images are in the same folder...
as for the saving, you should be able to set the settings to add another number at the end..
I worked it out, you make the action and then use the batch settings for the save.
Off to play cod as this might take a while....
