Processing Sony RX100 RAW in PSE9...UPDATE
Dave in Wales
Can it be done with a plug in or am I better of buying PSE11.
You will need to do RAW->DNG if you want RX100 support in anything not current. Lightroom only just (about 2 weeks ago) got upgraded for RX100 support. I suspect there is a download for PSE11 which would add RAW support in there...
You need the free DNG converter from adobe.
It does not recognise RX100 RAW files.
When I open the folder containing the RX100 RAW files all it says is 'No images match your search' on a blank screen.
UPDATE....Hidden in the back of the miniscule 'Instruction Manual' it referes to RAW and software called 'Image Data Converter' so I downloaded it.
This handles the RAW files for PP and will even export the data directly to PSE9 as a TIFF file if required.
If all else fails read the instructions.......Dah.
