- Chris
I have two Vivitar 28mm Wide Angle lenses, both Komine versions. One is the PK mount f/2.8 Wide Angle, but the one I really like is the PKA mount f/2.8 Wide Angle Close Focus very well regarded. However, I'm having a little trouble with the latter. The ring with the depth of field scale and the focus indicator is turning with the aperture ring, with no clicks! If I grip it carefully I can turn them separately, but it's not possible to do so in normal use. If it slips into A mode it's even harder to get out again.
I've checked using the depth of field preview on the Pentax MX (push the timer lever towards the lens), and the aperture is opening and closing depending on where bot rings are turned (and the aperture seen through the viewfinder telltale seems correct) so the lens is presumably usable. However, since the focus point indicator turns with the aperture, there's obviously no way to zone focus!
Any ideas? Time for a CLA?
