So, last night was shooting with a 5d using Interfit lights and a cheap ebay trigger...
Got it all set up properly, did a few test shots - everything worked fine (setting were initally 1/250, f11 I think... can't quite remember)
Took a few shots then had one with a line across the photo and everything under it dark, immediate thought was that maybe the shutter speed's too high so dropped it down to 1/125 but then had the same problem occurring intermittently with different amounts of dark area on the pictures.
By this point a little worried since I hadn't used the 5d with studio lights before, so tried with a 50d instead. Worked fine...until about 5 shots in when the same thing started happening again.
A solution came with dumping the trigger and using a sync lead instead - so Im thinking the problems must have been down to the trigger, anyone had the same problem?
Just want to put my mind at ease that the cameras are ok!!
