photographerian
- Ian
Got a weird one here. I usually use the *button on the back as the focus button. But swapped it the other day to the traditional half press on the shutter (hands very cold at Rugby).
Using the * focus method in AV Mode everything is normal
Using the shutter button 1st image is fine, 2nd image the shutter speed drops from 800/1000th to 125th. Causing the 2nd frame to be completely over exposed.
I've copied the settings from my 2nd camera so to eliminate something in one of the menus being turned off/on and still get the same problem.
Anyone any ideas. Before it gets boxed up and sent to Canon again.
