printing on a fixed ip adress help
wegotitugetit
On the hit list !!!
alex
so currently we have fibre optic in our premises and the router is set to
192.168.1.1
i ordered a rinter server from amazon and has a prefix of 192.168.0.1
as these two are both on diffrent band's i was advised to change to 192.168.1.250 which i have done
on a windows machine i can ping the 192.168.1.250 and it finds it
but if i go to printers then type the adress it does not find it
any ideas for this please
my mac can find it but does not print am i missing something here
the printer is a sharp mx-182d these are not a small printer from currys these are proper printers but would of cost almost £250 + for the same version with wifi in / to able to use as a fix ip adress
i really need some help with this please i have looked and cant figure out what i have missed
What is the subnet mask and gateway set on the printer (and pc's and router)?
It should be 255.255.255.0 and 192.168.1.1
To fiond out what it is on a PC, open a command prompt and run
ipconfig
on a Mac, I think it is
ifconfig
(well, it is on FreeBSD which OSX is based on).
on the printer server not the printer
the sub net was left the same as the original as i was told this
as for the ip for the printer server it was changed to 192.168.1.250 if you look on the net alot of people tell you to do this so im happy with that
all the pc are not static ip adress i have not had chance to go around all of them yet , never done it before on top of that the router interface is diffrent to what im use to so im going to have a read up etc before i start messing with them
depends if you already had a device on 1.250..
can you tell us the IP of both the mac and pc along with subnet and gateway. and what you have set the subnet of the printer to.
:agree:
Can't do any diagnostics without that...
im confused.
"on a windows machine i can ping the 192.168.1.250 and it finds it
but if i go to printers then type the adress it does not find it "
what exactly are you trying to achieve or is wrong?
printer is already working in windows on a home network
we need the fixed ip as not all pc's are connecting
ill have a look for the other settings in a min
We understand what you are trying to do, just making sure everything is set consistently and correctly.
That is a small printer ;)
Ignore the message, didn't realise you had a print server and a printer. It is always much easier to use the printer server built into the device as it also opens up other features that you may miss by using another printer server
