Printing in LR4
mercurius
I do most of my pp work in LR4 now, but before using LR4, I used to use ViewNX or CaptureNX and print using Qimage. Now I'd like to print in LR4 too, but can't work out if you can print multiple different pics in the app. It seems to be set up to print multiple copies of the same image, but not different images.
Am I missing something?
Select the images you want to print in the library strip at the bottom, then use or make your own template. These are on the top,left.
I have some of my own custom ones setup for printing my assignments with a border. Plus you can use/load print profiles, print to a file (for uploading to labs etc).
Select the images you want to print in the library strip at the bottom, then use or make your own template. These are on the top,left. I have some of my own custom ones setup for printing my assignments with a border. Plus you can use/load print profiles, print to a file (for uploading to labs etc).
Just to clarify, when you have selected (by flagging?)pics to print do you then go into the print module?
