Printing from an iMac
Phil Bennett
Philip
Guys
Does or has anyone had a problem with a Magenta colour cast when printing from an IMac, if yes, did you get a solution? if yes, what was the issue.
Its driving me mad.........
Phil
Guys
Phil
It would say its the printer,rather than the I-Mac :)
Cheers Simon, but I think Ive put it in the wrong section
Phil
Wrong section or not I would suggest you need to do two things.
1) first profile the monitor
2) the load generic profiles for your chosen paper ( available from the paper manufacturers)
If this fails then you need bespoke paper profiles
James
The only time I've colour cast problems is when I've been using cheap inks. I think Simon is right. Is this a problem that's just started or have you changed something?
Cheers Jim
Ive had the issue for ages, tried and failed to sort it, so didn't do any printing, but thought I might see if there was a solution out there, just wondering if there are iMac users on here, who print okay, or have had and sorted the issue out.
Phil
Mods please delete as Im in the wrong section.
Cheers
Phil
