Photoshop CS5 Help
Mark-Anthony
mark
Hi All
I'm pretty new to using certain features on CS5, So require a little help if i can?
Basically, I have been doing club photography and they require me to put their logo onto each image.
I've created an action and put the image onto all the images using the "batch" mode. However, i need to know this...
Is there an easier way to save all the images as the jpegs rather than 1 at a time?
You can see at the top that all the images are saved as tabs when doing the batch mode. as you can imagine, this is time consuming!
HELP!
I'm no expert on photoshop but can't you modify the action to do it for you.
When you record the action after you've put the logo on continue recording and save the image in the relevant folder and then close the image down. Then stop the action recording.
Then when you batch edit it should do it all.
I think!!!!
Ah yeah that makes sense. I'll try that now just incase. I was scared of it saving them all as the same image.
I'd make a copy of all the images just in case
Just tried that, no good. I'm having to save them one at a time which is doing my head in :(
