However, something that isn't mentioned - what do you guys do about finding out if you can set a hide up in certain places? Woodlands, riverbanks, etc, is it local knowlegde, getting permission, or just plain walking right in and doing it anyway? :shrug:
And apart from 'sod off, I am not sat in this silly tent for nothing you know' what do you say to anyone that approaches your hide?![]()
To be honest a lot of my photography is from inside woodland looking out into clear land, come spring and foliage,I will probably use it less and less.You tend not too mind sitting on the floor and crawling around trees too much when it is warm.......
That's really the appeal of a large sheet of Leafscreen cammo - just string it across a gap in a hedge, or acoss a couple of bushes and you're set up.
Hi All just for the intrest found this on the net
http://www.outdoorgear.co.uk/eshop....sc=QUICK+PITCH+SINGLE+SKIN+TENT+2+PERSON+TENT
http://www.ultimateaddons.com/Hunti...ness_Camouflage_Pop_Up_Hunting_Tent___923.htm
Now that was my first choice tooI'm a bit partial to the Pink Flombe' version in that first link.![]()
£119
Well, after much ummin' and arrin' I just ordered this one.
CLICKY
I'l post some thoughts on it in due course.![]()
Hi Gerald, that shot was not taken at ground level, but I was actually sat on the ground for it. If you look at my pic in post #37 - taken from the inside of the hide - you can see a zip going down from the center opening to the floor. This can be used as a viewing hole too if required. It's not designed that way, as this zip is the main access zipper if you want to get in whilst the hide is assembled fully. I don't use this as I tend to sit in the hide, then pull the frame concertina down over my head with all the zippers remaining done up. However, there is enough room to sit on the ground in front of the double chair (yes... with cup holderHi John
You might be able to answer the one question I have about the hides shown in this thread. They are all seem to be for shooting at eye level or above, anything sharply below that level you will have a downward looking image on the subject. Far from ideal.
Your image of the wader seems to have been shot at ground level. Are there opening in the hide you are using, allowing you to get down to ground level to shoot the low level animals?
Gerald
Hey CT, glad you like it, I am sure you will soon be putting it to great use. We need pics OK...
Hi Gerald, that shot was not taken at ground level, but I was actually sat on the ground for it. If you look at my pic in post #37 - taken from the inside of the hide - you can see a zip going down from the center opening to the floor. This can be used as a viewing hole too if required. It's not designed that way, as this zip is the main access zipper if you want to get in whilst the hide is assembled fully. I don't use this as I tend to sit in the hide, then pull the frame concertina down over my head with all the zippers remaining done up. However, there is enough room to sit on the ground in front of the double chair (yes... with cup holder) and use this zipper to peer through.
That's how I got so low with that Common Sandpiper shot. I wasn't quite at ground level, more 1'-2' up from floor.
Hope that helps Gerald.
I will say - it was uncomfortable sat on the ground at that place, pebbley and slightly damp...!! Great running water birding thoughThanks for your reply John.
I had a feeling the answer would be simple. I was expecting you to say, you laid on the ground and lifted the base of the hide a little to get the lens out.
Gerald
I will say - it was uncomfortable sat on the ground at that place, pebbley and slightly damp...!! Great running water birding though![]()
I guessing that there is no base to these hides. For getting low, and provided I don't have to walk to far, as it more kit to carry, then a camping ground mat, the ones you put under your sleeping bag, might be a good idea. It'll give you a little bit of padding and projection from the cold and wet.
Don't know how much use it would be on pebbles though.
If you don't mind me asking where was the photo taken?
I'd be more than happy to be a guide for a few hours if you want company... could even bring the hide with meI'm gald you put the map up as there are too many places in Wales called The Bryn![]()
I didn't even know there where Sand Martin in South Wales, and with the other birds, thats an excellent location. Next time I down in Wales, I might wonder over for a look
Gerald
Just shout or PM if you want, no probs - I'd be glad to show you that gorgeous place (and a few others close by).
Hi John
I thought exactly that when I looked at the web images, but I've just been doing some set up testing with the tripod, and I don't think it's really a problem. That 'bow' in front of you is only about 2 feet high. The only thing stopping you shooting downwards I can see is that you're sat rather far back in the seat. If you sit right forward on the edge of the seat frame you can shoot downwards at a very acute angle, certainly for subjects no more than about 6 feet away which is too close to focus with the 500mm anyway.
The only problem I see so far is that rather large front opening which gives a wide angle of visibility, but leaves you a bit exposed to view, so I'm going to get a big sheet of leafscreen cammo or similar, to just throw over the opening.
I'm, satisfied now that two shooters could shoot in comfort from tripods, so I'm pretty chuffed with it.![]()
If it's the same place you've ordered from they'll post it tomorrow for next day recorded delivery.
Just to add, I take a small piece of high density to foam to put on the seat if its really cold, them seats don`t keep your butt warm.........![]()
