PaulF
- Paul
Hi,
I changed my router from Sophos to Pfsense to enable the 2 xbox ones in the house to both get open NAT using Upnp. This I have done, both are open according to the xbox tests/reports.
I am having an annoying problem with COD Black Ops 3 though in that only the first xbox to connect can play online. The other then fails to connect and can only 'play local'.
Tha network options in COD report NAT as open too.
Any ideas?
I think it may be down to udp port 3075 being required by COD.
Other games work fine when both are being played simultaneously, Destiny, Fifa, Titanfall etc. I have also taken my xbox to work and not had an issue when it was on a different network, this was to ensure no license or xbox account issue so I know that's not the problem (we are using the xbox Home setup)
Any help would be greatfully received.
Paul.
Any ideas?
Paul.
