that's a cracker Jim - I spotted it on the Condor Instagram feed myself, then noticed you'd commented and claimed the bike
When you get a chance to put some distance on it, I may be picking your brains over the HyRd brakes and the Strade Bianche tyres - the current stoppers on my CaadX are a real P.O.S. to be honest, and an upgrade has been on the cards since I bought it - plus some decent road (with excursions to gravel occasionally) tyres wouldn't come amiss if I'm actually allowed outside to ride in the near future...
OK folks Mrs Clause is letting me get a set of wheels for my Christmas so I have been window shopping.
Currently I like the look of the following -
Campagnolo Scirocco
Campagnolo Zonda
Mavic Cosmic
What are peoples thoughts on the above and is there anything else I should consider?
I like the idea of a slight aero rim. To be honest if money was no object I would get a pair of Mavic Cosmic SLS but I think she who must be obeyed won't like the concept of wheels that cost more than the bike ha ha
Mountain bike sizing is different to road bike sizing as you need to allow for more stand over height on a mountain bike.
In the event of an unplanned stop where you need to get a foot down on uneven ground you need the extra room to avoid hitting sensitive parts on the top tube of the frame
I'm 5'9" with 29" inside leg and have a small giant trance FS mountain bike but do find it a bit short on cockpit space on the climbs and feel ok on a friends medium size salsa. I've changed the handlebar stem and seat post to give me a bit more stretch.
My road bike is a 54 frame and I find it spot on with a 100mm stem.
Hi just looking at this thread. So sorry to worry you but ulnar nerve operation for me has been tried three times de compression ie release and relocation and four years later no pins and needles but horrible elbow pain and ulnar claw hand. I do wish you luck mateNot as drastic as that thankfully.
It's ulnar nerve compression in my elbow (funny bone nerve) fairly simple procedure I'm led to believe, should be out the same day.
Just don't google the images like I did.
Since June I've not been able to ride the bike or play golf which is gutting.
Op will allow nerve to heal at around 1mm a day, so hopefully pain free by Xmas
we haven't but about 10 years ago I had a problem with a herniated disk. What's the link between lower back and foot. Is it something to do with pedallling action?You sure it doesn't come from an issue higher up? Sounds more like a lower back problem to me (have we talked about this before?).
just nerve related really. lower back issues can travel down the leg.we haven't but about 10 years ago I had a problem with a herniated disk. What's the link between lower back and foot. Is it something to do with pedallling action?
Is your saddle too high?
If it is it could be causing you to over extend your leg and also prevents a good/flat contact with the pedal?
Also, are your cleats too far forward?
Edit: your shoes aren't too tight / too thick socks?
Gotcha, it took some time before the sciatica wore off. I haven't had any complications recently and am reasonably confident that it's not a throwback to that but you never know.just nerve related really. lower back issues can travel down the leg.
in other news.. new major bike upgrades inbound![]()
OKay, another suggestion on the set up of the shoes effectively, I'll experiment, thanks guysFirst commute since the accident today, yay! My goodness that Fratello rides beautifully.
As for the pins and needles it can be due to "hot foot" which can be an issue with the small footprint and can be sorted with either stiffer shoes or road pedals with a larger platform. It can also be because of doing up your shoes too tight. Or it could be back related. I would exclude the simple things first.
Transition Patrol (Satin Black with Neon Yellow Decals)And the bike is?![]()
Dod, get a pro bike fit.
The difference in my set up now compared to my initial riding position is massive since getting fitter through the summer.
My bike had a basic fit at purchase which fitted how I was then, but as weight came down and I got fitter and more flexible I started getting right knee pains after about 30 miles. I went for a pro fit which used lasers and slo mo video to capture how I actually ride and ended up in a totally different and more powerful position.
good quality insoles in the shoes will help with tingles though as it can take the pressure away from the nerves which get pressed against the pedal axle.
I've booked one. The other issue I get is stiff elbows and I'm guessing that's got to be a setup thing. Will be interesting to see what gets recommended![]()
I've got arms like T.RexI thought the stiff elbows was a Scottish thing, it stops you lot from putting your hands in your pockets when it's your round![]()
Do any of you guys use a turbo trainer for the darker/wetter months?
I'm looking at one to help keep the fitness up over the coming months as I'm finding it harder and harder to find the time on a weekend and weekday evenings are a no-no now it is dark so early.
I've seen the Tacx Satori Smart trainer and it can be linked up to Zwift or BKool to get interactive training. (Not sure how this works in reality as I need to do more research) I don't want to spend a fortune on one so looking around the £150-170 price range.
I think @TheBigYin uses one but not sure about @digitalfailure or @stupar etc.?
Any help/advice greatly appreciated.
