TriggerHappy
- Jamie
@TriggerHappy - is the weather bad up your way that you need wider tyres this time of year? In London I've yet to see a flake of snow on my morning commute.
I'm also curious if 2mm makes a difference? I've never ridden a road bike before so these numbers are all new to me. With my mountain bike all I ever did was replace the knobbly tyres with slick-in-the-middles when I wasn't actually on a mountain! But it seems road bikes are more finicky with how you set them up.
The weather isn't especially bad. Cold and wet mainly. There's plenty of ice staying on the quiet country roads I usually ride, particularly where the hedges have kept them sheltered. The problem is when you a) can't see the ice or b) can't dodge the ice because it's a big patch or there's other things around you that stop you avoiding it.
The tyres make a small difference, obviously if you hit ice and don't do the right thing you're screwed regardless. The main reason I wanted them was for a softer ride than the 23s give. 23s can be punishing at times, and no faster where the road surface is poor. I suppose the change of tyre is as much the psychological confidence boost of having adjusted for winter roads. I'll also run them at a lower pressure to try and get a slightly larger contact surface on the road.
The nature of road tyres makes them pretty useless on anything other than smooth tarmac. As soon as you introduce ice/mud/grit they're a liability. In an ideal world I'd own a cyclocross bike as well so I could have some more all purpose tyres to ride on and forget about but I don't have the money for such an indulgence so it's a case of being sensible until the warmer weather comes!
. I don't get out on the road bike as much as I should, chucking the other one around is too much fun!
