Pano building help
Harvey_nikon
Hi,
On a recent trip to Windsor I managed to grab a few decent shots amongst all of the normal touristy ones :)
Got an 8 image pano from inside the castle and would like some advice. I've added sky in to correct errors in creating the pano and cloned out the tips of some gate spikes however the main issue is the building verticals:
Is this correctable without destroying the image, and if so how?
I take it this has happened due to shooting with 18-55kit lens at 18mm??
I had same problem the other day when i stitched using the auto method in cs4. I tried stitching with perspective method and all was good. If you dont get it to work to you liking you could try this.
In cs4 try using the marquee tool to quickly highlight the building you want to straighten then go to edit, transform, rotate and rotate the building then go to select and deslect. Click on the history brush tool and clean up the space around it. Use a small brush...
CS4 crop and perspective tool seems to work on this image, if it's just the building verticals that are the problem :)
Apply a crop frame to the image, tick the perspective box and drag the corners to correct the aspect. Had a quick play and it certainly sorts out the right hand side :D
have a go with the transform/warp tool....u can drag any corner of a box till ** happy (not just the outer corners) again this is in photoshop
gary
