Yes, so much lighter than hauling my old D810 round!! As superzooms go, the 24-200 is very good as the image quality is decent and the zoom range is useful for most eventualities (as long as it’s not fast moving, low light or a long way away). And with the resolution of the Z7 sensor you can crop hard if needs be, and low light can be tackled with a high ISO and Lightroom denoise.I’ve got the same lens set up. It’s great for landscapes as covers all bases. Both are relatively small and light so I don’t mind carrying both.
normally I’d put one or the other on the camera depending on where I was. If it’s a trip to the grit stone edges in the peaks then 14-30 usually. If in the lakes then the 24-200 would likely be on the camera. Such a versatile single lens for mountains.
Bad boy!My Ricoh GR3X is getting neglected.
It all depends as you say. But for personal projects I’m increasingly drawn to 35mm FF focal length. Most likely GF45 on GFX. Runner up Canon 35 1.4 m2 on R5.
For digital I have an Olympus EM1 MkII and the 12-100 F/4 Pro lens. It does everything I need.
I'll likely get a small prime at some point (did have the 17mm F/1.8 ages ago)
A 16-800 f/2.8 would prove limiting for me, even ignoring my general dislike for super zooms.5d4 with 24-105mm sigma art. Ideally though a 16-800mm 2.8.....
That has happened a few times on trips over the years, but I have them 'just in case', as I have used them occasionally in the past. The 16-80mm (24-120mm FF equivalent) covers almost everything, 98% of the time.And if you could only carry one... just the 35mm?I often used to spend days in the hills photographing the land with just an 85mm.
Many focal lengths in the 'middle sector' can fit that description, but I think that such an attitude is something of a red herring, and just an adopted mindset that can be risen above.
Currently I may carry a 24, 25 or 28, & a 50 ... or just one of them. Or just a 35.
I often do that.
Yes, that or a 50. Because in the limited terms of what I do, they're so versatile.And if you could only carry one... just the 35mm?
Prime by choice in an ideal situation because of wide aperture, compactness, weight. But then I have to decide which prime, as I seldom go out with a specific purpose in mind. So I go zoom ....It seems generally, from a quick scan through, that there's the prime lens camp and the super zoom style camp![]()
If (at least) one of them is premounted on a tripod it's not that difficult.I find it tricky to use more than one camera and lens at a time.
So maybe a RX100M6 or M7 for that compact range.Tried an X-H1 with the 18-135 as a one body/lens combo but missed the longer end so tried the RX-100 as a one compact option but still missed the long end. Current option seems the best compromise so far - an RX-10iii. Not perfect but nothing is (except for Mrs Nod [who isn't looking over my shoulder!!!])
Only practical for recording events changing reasonably quickly with time or needing long exposures.
I used two simultaneously at a recent fireworks show, (tripod for longer exposures handheld for short) and it seems to be reasonably common for eclipses (typically wide angle & telephoto).
