On Shutters
There's more than one, Grandagon, and later Grandagon-N f4.5 of f6.8, I have the f6.8 N and it's a superb lens.
Ian
The N are above what I am prepared to pay for the moment, the Grandagon 90 MC i have found a good one, serviced, at the what seems a reasonable price when compared to the N. Its f6.8
@Barney, before you buy a 90mm lens I'd better check the minimum bellows draw perhaps. At 90mm you may be screwed as far a a full set of movements go. When I got the camera I used a 135mm convertible Schneider lens and never used it with anything wider.
I did wonder that. A 90mm should focus with a standard lens board but will be extremely tight, hence the sales literature suggesting a deep recessed lens board with the 90mm lens. The other issue is the width of the Grandagon f6.8 front cell, they show the early 50mm f8 in the Compur #00 shutter, might be tricky using the controls.
Ian
The illustration of the deep recessed lens board I posted yesterday showed the 65mm f8 SA in a Compur #00 lens. For comparison here are two new (as in unused) shutters.
Left is a Compur #0. right a Prontor #00. The different sized Compur, Prontor, and Copal shutters are all have very similar dimensions, and the same thread sizes.
Ian
Does the flash connection go on the shutter or the lens?
Obviously, on the shutter - that's what you're synchronising to.
Are they standard on all shutters or do I need a specific type?
Only US shutters use different flash connections, so you will be fine, British, French, German, and Japanese shutters, all use the same which is an International standard.
Ian
Take a look at the Jollinger page (above). While newer shutters tend to use coaxial plug, I've had the "pleasure" of making up cables for several shutters over the years.
That at least is clear.
Get a 150mm lens with a shutter. That's all you need until you know what you want. If you can find one, get a Symmar - NOT Apo Symmar, NOT Symmar S. Reasons withheld to avoid confusing you.
Morning,
What is a fair price for this lens in copal 1, clean glass and CLA?
Roughly £150 for a 150mm Symmar or Symmar S, a lot more if it has just had a CLA. Personally, I'd go for the Symmar S, they are in Copal #0 shutters. I have a 135mm version.
Ian
Ian
Thanks for reply
What is the benefit of Symmar S?
It is more modern, slight optical design improvements, and multi coated, so a newer shutter. Older plain 150mm Symmar lenses will have had a lot of professional use.
Ian
Ian
Will it still have dual focal lengths?
No, but when using just the rear elements of a Symmar the results are very soft even stopped down, OK for soft focus portraits. Not a reason to buy one.
With leaf shutters you need to listen to how smooth the slow speeds are, 1 second & ½ second, they must not falter or hang. If you buy from a dealer you would get a 6 month warranty.
Ideally you need to meet up with an experienced LF user, you are probably too far from me.
Ian
Ian
Just looked at some symmar s and coating deterioration on the inner looks like a common problem
Schneider lens sometimes suffer from what's termed Schneideritis, it is not a coating issue and has no effects on image quality at all. It sometimes happens with other manufacturers lenses. It is where the edges of glass elements have been painted black.
Ian
Ian
Are Nikon W any good?
Yes, excellent lenses, I have a Nikkor 240mm W.
Ian
I bet you have every lens going, Ha Ha.
I can only find them in 0 and max SS of 125 bothers me.
A 150mm f5.6 Nikkor W is always in a #0 Copal, top speed is 1/500,
Copal #0 1/500
Copal #1 1/400
Copal #3 1/125
Copal never made a #2 sized shutter.
150mm f5.6 and slower are in #0 shutters. f4.5 #1, f3.5 in obsolete Compur #2
210mm f5.6 and slower are in #1 shutters. f4.5 in #3
90mm WA lenses are generally in #0 shutters inc the 90mm f4.5 Nikkor SW, the exception is the 90m f4.5 Geronar which is in a Copal #0
Ian
Remember that typically you won't be using a large format camera to photograph cricket matches where you positively have to freeze the ball in flight just before the batsman thwacks it.
More seriously, you will normally have a lens of f/5.6 or slower (I have some f/9) and will be stopping down for depth of field or coverage. Lens specs for coverage are usually given for f/16.
The slower shutter speeds are more relevant to me.
