LOL. Thanks Ian it gets me right 'ere... honest.![]()
Either that's a hijacked account or the seller is very very lazy.
For a 3.5k lens you don't just put one sentence then copy the specs from the manufacturers website?
This is a full frame 1D shot, and the nearest I'm going to get to a serious attempt today. Unremarkable except it was shot through tinted glass, 1/80 at F5.6 and 800 ISO with the 1.4xTC.
Gonna put it away now and RTFM.![]()
Thats pretty good for 1/80 at 500mm!!!
That's a cracker ... and look at what that lens has done to the bg, that's why you pay that sort of money for these lenses.
Congrats on the new toy CT![]()
Hmmm ... suppose this means your stuff just got that much better then Cedric ...
... mighty glad Nikkor range don't got a 500 VR ... yet ...
I've just done my £4.7k on the 600 tonight .... bit bizarre as I haven't even got a Canon body to use with it yet![]()
When you gettin it?LOL You mad impetuous fool.When you gettin it?
I bet they will though.![]()
It'll be 600mm and f/4...allegedly. But I didn't tell you that, geddit?
Mine's getting Cammo'd up shortly anyway.
If you focus on a given subject/ range then press the 'SET' button to the left of the three position switch (partly obscured in the pic) you store that focus position in memory. You can now focus elsewhere as you please, but should an opportunity arise at your preset focus spot, then to recall the setting you just nudge the white knurled jog wheel which is towards the front of the lens. It only moves a fraction left or right, and it matters not which way you turn it, it instantly recalls your previous focus position. It's very fast and accurate and works whether you're in AF or MF Mode.
Fantastic, and potentially a really useful aid to bagging the shots, which is more than I can say for the AF Stop function.
If you look at the back rubberised band towards the front of the lens you can see a black micro switch. There are actually four of these at 90 degree intervals around the band. Pressing any of these halts the AF function (overriding the shutter button) until you release it, when AF resumes.
For the life of me I can't think of a situation where I'm likely to need it, or be able to find one of 'em in the heat of the moment, especially being so far forward on the lens.
Time might prove me wildly wrong, but the jury's out. :shrug:
That's interesting... so, unlike my Nikon 300/2.8, the 4 focus lock buttons don't double-up as focus preset recall buttons.
Inside information suggests it will be black![]()
Nope - they don't have any useful function at all as far as I can see. :shrug:
I wont be sending it back though.![]()
If you get a screwdriver and a soldering iron, you may be able to transfer the ring switch wires to the buttons... go on, it'll be a laugh![]()
Canon has more need to use reflective bodies than others, principally because of the fact that they use flourite based elements (well a single element because it is so expensive), flourite based glass is particularly fragile being prone to heat and shock.
That's what the ED glass in Nikkor lenses is too...
