imattersuk
- No
Another great car shot in the thread.
Red Deer 3 by -Rob'81-
Red Deer 2 by -Rob'81-
Red Deer 1 by -Rob'81-Whereabouts was this ?I’m still trying to get to grips with the 400 f4.5. I’ve been going to my local deer park as the deer there are usually quite good subjects.
This fella has quite the facial disfigurement. I’ve never seen a disfigured deer at the park before. With it being a managed deer park they breed the deer specifically choosing the best to get unnaturally large antlers, so I didn’t expect to see a deer like this.
I’ve been trying to capture a deer looking around a tree for many years. Typically a get the pose but it’s looking around an awful metal guard, which seem to multiplied this year.
I have to give it up this fella as he’s quite the poser. Hopefully will spot him in the rut in the autumn.
So far I’ve been really liking the lightness of the 400 f4.5. I’d normally take out a small tripod but I’ve only shot hand held so far and it’s quite refreshing to more mobile. It’s a steep learning curve getting used to a prime again as I’ve only shot with a zoom lens for wildlife for 10 years now. I’ve got so used to being able to twist the zoom for close or wider shot.
It’s Woburn. Very hit and miss as you have to stick to the public foot paths and can’t walk anywhere you’d like to. The light weight 400 f4.5 really helps keep weigh down so you can’t walk further to find them.Whereabouts was this ?
It was quite annoying when I moved to canon hoping to get the 400 f4 to then see Nikon bring out this on mirrorless and so much lighter.Definitely a lens I’ve had an eye on for a while, even while not shooting Nikon. Hopefully one day I’ll get one.
Yes I had a feeling it was Woburn, I was up there a couple of years ago, but as you say hit and miss, but if you have a decent lens, it,s possible to get good shots from some of the footpaths, I've only got a 70-300 and another 100mm would of made the difference.It’s Woburn. Very hit and miss as you have to stick to the public foot paths and can’t walk anywhere you’d like to. The light weight 400 f4.5 really helps keep weigh down so you can’t walk further to find them.
If you play the odds with a few visits to find them close.,300mm would be fine as I’ve use around that before. These weren’t that far away, I had to keep moving back along the path with it being a fixed 400mm. I’m not used to a prime having not used a long prime for 10 years (and that was a 300mm prime).Yes I had a feeling it was Woburn, I was up there a couple of years ago, but as you say hit and miss, but if you have a decent lens, it,s possible to get good shots from some of the footpaths, I've only got a 70-300 and another 100mm would of made the difference.
That’s nice. I’m thinking of visiting one of my old water vole haunts but I’m not sure if there any still there
The Martians are coming by Trevor, on Flickr
Severn Belle by Trevor, on Flickr
Eric Bedser 3 by Trevor, on Flickr
Alec Bedser-2 by Trevor, on Flickr
Coffee stop (Portra) by Trevor, on Flickr
Let's stop for coffee by Trevor, on Flickr
OSR small 4 by Peter Stephens, on Flickr
OSR small 2 by Peter Stephens, on Flickr
OSR small 1 by Peter Stephens, on FlickrYes. Check out D6 under custom menu, to make sure 5:4 ratio is selected. Otherwise you won't see the option when choosing.Nikon Z7 and Nikon Z7 II "Grid type display" choice of ratios.
Can anyone tell me if this 5:4 ratio "display" grid is an option with the Z7 and/or Z7 II (without using the 5x4 ratio file crop).
This seems impossible to find by googling !!
Thanks, I don't know why this seems so difficult to find. It's easy to accidentally find out about the Zf and Z8 while searching on the Z7 and Z7II, but not for the Z7/Z7II.
Search Google 'AF8images' videosThanks, I don't know why this seems so difficult to find. It's easy to accidentally find out about the Zf and Z8 while searching on the Z7 and Z7II, but not for the Z7/Z7II.
I'll give that a shot. I've watched a couple of "setting up" videos but they didn't cover this.Search Google 'AF8images' videos
Thanks and that is correct, and as far as I know Nikon has always done this, but that is the 5:4 "crop", it isn't the 5x4 "grid display " option that I was asking about, and listed, which for the Z8 and Zf are 3x3, 4x4, 5:4, 1:1 and 16:9.If I recall shooting in 5:4 on the Z7ii crops the raw file to that ratio.
I've now looked up this Youtube channel and can't find a video that explains this.Search Google 'AF8images' videos
Pie Shop by Stephen Lee, on Flickr
Skipton High Street by Stephen Lee, on Flickr
Skipton Canal Basin by Stephen Lee, on Flickr
Cruisers by Stephen Lee, on FlickrTerrific. I’d have only taken one picture. Wouldn’t get past the pie shop….Had half an hour to spare yesterday in Skipton so I had a wander with the Zf and the manual Nikon E 35mm f2.5 lens (as supplied by @woof woof - thank you)
There’s another pie shop 10 yards away. Despite much testing I can’t decide which is better …Terrific. I’d have only taken one picture. Wouldn’t get past the pie shop….
Once you’ve fondled one you have to have it…I pulled the trigger on a zf last week (after constant daily hounding by @imattersuk - telling me how much I’d like one). We met for a beer in the big smoke and after I got to fondle his one, I was hooked.
Have tried an old sigma 300mm f2.8 adapted and the focus works. Will find out tomorrow if it locks on and tracks adequately, but first impressions are positive. That line of lenses are not officially confirmed to work with the adapter.
I feel I need to set the record straight here and impart an accurate accounts of events.I pulled the trigger on a zf last week (after constant daily hounding by @imattersuk - telling me how much I’d like one). We met for a beer in the big smoke and after I got to fondle his one, I was hooked.
I thought you were referring to the ratio setting, not a grid.I've now looked up this Youtube channel and can't find a video that explains this.
There is a video about changing the "image area" and another on changing the display grid, but, like everything else I've found, he only mentions 3x3 and 4x4 in the display grid video. He mentions 5x4 when explaining the image area options, but of course, that isn't what I'm looking for.
Am I just missing the video where he shows how to set up a 5x4 display grid.
@addicknchips - I’m buying Sony
Me - don’t you’ll be bored within days, just like you have been 20 times before
@addicknchips - it’s cheaper than the ZF
Me - don’t be a skinflint all your life
Sony meets ZF in London
Next day I get a message to say a delivery is imminent
The end
Sorry I tried to make it clear I wasn't referring to the image/crop ratio, but to the grid overlay feature.I thought you were referring to the ratio setting, not a grid.
Yeah. But it’s beautiful innit….In my option you need to be related to an octopus to find the ZF's comfortable to hold without a grip. Nothing like the a Sony.
As far as the framing grid is concerned, it's fixed at 4x4. Your only option is on/off and can be assigned to a button.Sorry I tried to make it clear I wasn't referring to the image/crop ratio, but to the grid overlay feature.
As far as I'm aware being able to set the grid overlay ratio independent from the image crop was introduced with the Z9 and is now on the z8 and Zf. But I also thought it might have been added with a firmware upgrade to the Z7. But I cannot find any reference to what grids are available on the Z7 other than discussion from people wanting a rule of thirds grid that was introduced with the z6..
I'll be diplomatic Trevor and say... Not my cup of tea. The last time I picked up something like that and quickly put it back down was one of the Fujis. To be honest I'm rather disappointed in Nikon copying their old, old model.Yeah. But it’s beautiful innit….
No problem mate. I appreciate it’s not for everyone.I'll be diplomatic Trevor and say... Not my cup of tea. The last time I picked up something like that and quickly put it back down was one of the Fujis. To be honest I'm rather disappointed in Nikon copying their old, old model.
Thanks, that is what I feared, given I couldn't find anyone discussing grid choices.As far as the framing grid is concerned, it's fixed at 4x4. Your only option is on/off and can be assigned to a button.
Which is why I originally discounted getting one after holding it, then I realised that Nikon were giving the excellent smallrig grip free, transforms it and regardless of whether or not people like the styling it massively outperforms the Z6II & Z7II when it comes to AF performance, it even has subject detect in manual focus, not even the Z8 has that. Compared to the Sony A7IV I had it's different class, Sony should be ashamed to sell that with the crappy EVF, screen and slow burst rate.In my option you need to be related to an octopus to find the ZF's comfortable to hold without a grip. Nothing like a Sony.
