realspeed
- Bazza
- No
yellow mark is the flat ring around the lens (has filter on as a clamp)
The protective flat plastic screw cover on the nikon AfS 24-70mm G lens came unstuck and I can't see anywhere to obtain another. So reusing exisiting one. Big problem not to get glue onto lens glass so applied a glue (not super glue) onto the flat ring first. To clamp it down I am using a 77mm filter and hope it works and it does
