AchimT
- No
The D800 is noticeably bulkier. Both are IMHO easy and intuitive to use. The D800 menu structure is in some areas quite different and has a lot more options, not all of them of interest to every photographer I assume, but I guess it's a pretty complete set of features. On a side note, why anyone would use image editing software built into a camera with the obvious limitations in usability is beyond me, but the software is there alright.
The D800 does not have an Auto (A) mode. However, it has a lot more buttons which allow me to make all the adjustments (for example switch the type of metering) I need more quickly. You want to shoot a landscape with a rural barn which is open on one side? Matrix. You want to shoot the barn and see what's inside? Spot, it's the flick of a knob on the D800.
The D600 also has a decent set of buttons, but the D800 is better. The flash of the D800 is stronger, but in terms of strength still not on par with a good external flash unit. The printed manual of the D800 is a little taller than that of the D600 and these 2 (or so) centimeters add a whole new world of readability. I've never read the paper manual of the D600 because it was nearly unreadable for me, while the readability of the printed D800 manual is good.
The dynamic range on both cameras is comparable, and so is the image quality. For hobby photographers like myself, the added 12Mp of the D800 allow for even more cropping, provided you had a good lens. The D800's AF is faster and more reliable, and the AF points cover a larger area, but the latter is irrelevant for me. Both cameras have good metering, the D800 seems to be a little better in determining the right settings.
The continuous shooting speed of the D800 is lower, but it maintains this rock-steady, while the D600 seems to shoot in shorter bursts rather than maintain a steady 5fps. The D800 has a CF slot, which is not bad as the CF cards have (as I read) their own controller, so the camera just hands the images over to that without having to bother about writing to the card - maybe that is the reason for the steady CH burst speed.
In the D800 viewfinder I can see a better DOF preview. I was told this is due to the viewfinder being a tad grainier, but for me, only the fact matters that I can see better what will be sharp and what will be blurred.
The D800 has an artificial horizon indicator shown in the viewfinder (press a button to turn it on), I forget whether the D600 had that too. It's handy though. You won't believe how often you don't hold the camera properly aligned horizontally or vertically.
There are probably more things I've noticed when using the camera, which I have forgotten to mention now, sorry for that. One major difference maybe, my D600 had the sensor dirt issue, the D800 was entirely problem-free.
Both cameras take great pictures. The D800 is for all practical purposes of me as a hobby photographer probably not £500.- better than the D600, but it is a great camera.
