Nikon 70-200 f2.8 v 80-200 f2.8
Rockshifter
Charles
I'm thinking of one of these fast zooms for indoor sports.
The 80-200 is about half the price of the 70-200.
I'm using the D300.
Any advice welcome.
80-200 is :thumbs: on the D300, although for indoor/lowish light the 70-200 might be better. If Calumet ever get round to sending me my 70-200 I'll post some side by side shots :shake:
Cheers Flash.
Do you take most of your shots on this lens with a pod ?
The 70-200 does have VR. Is it worth paying double ?
Cheers Flash.
I haven't found the need for a monopod, the glass is fast enough to get sharp shots handheld. The advantages I can forsee of the 70-200 are the AF-S and to a lesser extent, for me anyway, the vr. Is it worth £5-600 more? I hope it is, but until I get ahold of one and use it in anger I can't really say.
I tried both, for me the 70-200 VR is absolutely amazing and shines over the 80. Super fast, super sharp, super everything.
I'm using the D300.
Any advice welcome.
For sports you won't be using VR. I have the VR version and I love it. Never used the 80-200 so can't compare.
The optics are supposed to be near identical, but if you're right then I'll (eventually :bang:) be a very happy camper, because the images from the 80 already seem pretty impressive to me :D
Advantages of the 70-200: silent focussing; VR.
Advantages of the 80-200: build quality, size/weight.
At the risk of sounding like a pimp, I know a place where you can hire them both to see which one you get on with best...
I have the Nikkor 80-200mm F/2.8D and i'm really pleased with it, I wouldn't pay double to get the 70-200 as I don't think it's possible to improve on the sharpness, you can pick a good one up on ebay for £400ish you could get the 80-200 and another quality lens for the price of the 70-200.
Looks as though most feel the 80-200 will do an excellent job and a he'' of a lot cheaper.
Looking to go for it.
Flash - I'd like to use this lens hand-held at ice hockey (very poor lighting) games.
Will I get sharp images ?
A little tip - try to get the 80-200 AF-S not the 80-200 AF-D.
The AF-S works better on a D3 / D700 than the 70-200 VR, and optically they are identical on DX.
You don't need VR for indoor sport, you need fast shutter speed to freeze subject motion. At say 1/250+ even at 200mm thats plenty of speed to handhold. VR will actually introduce a bit of lag.
Puddleduck
I've got d300. If they're identical why should I go for the 80-200 AF-S ?
Is there a price difference ?
They're not identical, the af/s is silent wave focussing, the af/d is cam focussing.
It's not a straight swap, the af/s is no longer manufactured, and that doesn't even make them cheap, even if you could find one.
I would think you'd be looking at the thick end of 6-£700 for a secondhand 80-200 af/s, the af/d could be bought new for that.
The bang for buck lies with the af/d, the af isn't as fast as either the 80-200 af/s or the 70-200 af/s vr, but it isn't pedestrian.
Both the 80-200's are legendary, I'm sure the 70-200 will also become so.
Make sure you know which af/d you are looking at, some of the older models do have slow af.
80-200 af/d ed
80-200 af/s
70-200 af/s vr
easiest way to tell the difference between an af/d and the af/s at a glance is the af lock buttons on the side of the af/s between the grip rings.
well i played with a 70-200 VR and i will be buying on of these.
so i cant comment on th 80-200. but i would have thought i was a good but i am going for the legend
80-200 af/d ed
80-200 af/s
70-200 af/s vr
:agree:
Another quick way to diferentiate an af-d from an af-s is the lens hood as the af-s has one which is similar to the 70-200 in shape. Assuming of course that the hood is fitted :bonk:
I know a pj who prefer the older push-pull 80-200 af-d over the newer 2 ring version, as he says it is easier/quicker to zoom, but I guess that is down to personal taste, also any push-pull 80-200 is going to be an old,old lens.
I have a push puller, it is quicker to zoom but the af is slow compared with todays tele's, banging glass mind, sharp as a b****r and great for anything not moving too fast.
Un-fortunately, this push pull design doesn't lend itself to dust free optics, mine has loads of dust in it, but its built for f/2.8 so it doesn't matter.
