Nikon 18-700mm lens - am I missing out?
Mozziephotography
Stephen
Bought an Nikon 18-70mm lens for myself for the princely sum of £80 a couple of years ago. Taken it on holiday with me and use it at home from time to time. I'm really happy with the results. Am I too easily pleased and am I missing out on something that the way more expensive lenses could do for my images? My significant other has one too. Are they available "NEW"?
18-700? That's some lens:eek:
Unless the laws of physics were demonstrably suspended to
the benefit of Nikon, I would not consider a solution like that! :rolleyes:
My old Nikon D70s had that lens as part of the kit. I too found it a very good lens and should never have sold it
The 3rd best kit lens I've used, the best being the Fuji 18-55, 2nd the Nikkor 24-120 f/4 then the venerable Nikkor 18-70. Would still have it if I had any Nikon Dx kit.
The best kit lens bar none was the Pentax 16-45mm f4. Samsung also did a version and for £140 they were stupidly sharp even wide open.
The 18-70mm certainly bats way above its price range.
It's a nice lens. I used it a lot on DX, where it directly replaced the 28-105 I'd shot on film. It's sharp, focuses quickly and is well constructed, with a proper metal mount and a decent hood. If you want to look for flaws, the distortion at the wide end is significant (much more so than the 28-105 at an equivalent angle of view on FX). Straight lines are not so straight, and it's less than ideal for architecture. I don't know if this is something Nikon have improved with more recent DX lenses - I can imagine designing something that works well at 18mm is pretty challenging.
You are lucky if you are happy with budget lenses. I have thousands worth of lenses and never have holidays so who is better off ?
In terms of image quality, the benefits of a more expensive lens would be marginal at best. If you want to expand capability at the wide-angle or telephoto ends of the range, then look at getting an extra lens or two.
One thing you're currently missing through is much control over shallow depth-of-field with low lens f/numbers like f/1.8. Maybe consider a 50mm or 35mm 1.8 as a very affordable way to scratch that itch.
Hi @HoppyUK I take the 18-70 on hols to limit weight. I have 35,50and 85mm prime lenses to cover the events I attend. Took the 35mm on a trip to India. It did the trick and was as light to take round.
Then you're pretty well covered :) Apart from maybe macro (Raynox adapter is an affordable way of testing the water there) and how are you fixed for flash? A decent flashgun is one of the most underappreciated ways of dramatically enhancing so many situations while also opening up new opportunities.
Failing that, it's full-frame :eek:
Have a 40mm macro - the 105mm macro I had was too heavy for her indoors and we sold it. Regret that. Flash - wanted one for runners in bad light, but speed wise I don't think it will cover it.
Not sure I understand what you mean there, but get a flash anyway, and learn how to use it properly, which often means pointing it anywhere except at the subject ;) Most people never get to use flash to its full potential and don't know what they're missing. I use flash for about 75% of everything, indoors and out.
The flash wouldn't cope with a runner when the shutter setting is above 1/250th sec as far as I can work out. Unless I panned?
Several ways around that, with high-speed sync being the obvious one, but with normal sync or slow-sync the flash duration itself is very brief and will freeze movement. Balancing flash with daylight is a basic skill and easy to master.
Does not compute! I'll have to read up on this but I'm sure I've searched this before. There's a Nikon flash unit for sale at the moment on one of the thread. Nearly bought it.
Yes, do look into it :thumbs: I just put "runners" into google images and in 90% of the shots either flash was used or could and should have been used for best result. The trick is making it look natural and all that takes is a bit of basic knowledge about 'how light works' and practise. Practise, learn, practise, learn, and ask a few questions in the lighting section along the way.
If you want to make your images pop with colour and vibrance, never mind your fancy lenses - get some good light in there :)
