ajc
- Andrew
- No
Any pointers?
I started to use it in in a USB type external enclosure. Kept getting USB hub errors all the time (annoyingly these SATA, as opposed to older PATA 2.5 "drives require 2x USB port worth of power it seems).
Struggled like that for a several months (mostly getting it to work for a varied number of minutes using just 500ma worth - ie 1x USB port connection only) ... and stupidly used it as my MASTER drive for all my RAW photos ... DOH ! :bonk:
Then would not work.
Then would work when tried it in new external enclosure.
Then wouldn't AT ALL.
Then did work in a store's external drive.
Then purchased Cardbus 32bit eSATA card and tried to work - not recognised in My Computer (and now cannot get to spin up in any older external enclosures either ... via USB or new card).
Have my different voltage inputs damaged it? Is it fixable / or rather is some sort of safety protection kicked in ?
(Rather miffed as there are LOADS of GBs worth of files in there that are ORIGINAL and not backed up :shake
Any help gratefully received (PS - I have older laptop that natively takes older PATA IDE drives .. so cannot try directly in there). Should I try to find someone with SATA (laptop) and try it in there ? Or what else (before I come to conclusion it is simple 'gone') ??
