New Bosch SDS Corded Drill advice
Either Makita or Bosch. I use heavy drills on an almost daily basis, I have gone through my fair share of machines, but by far the best in terms of performance and build quality are Makita and Bosch. It depends on what you are drilling, key chuck drills have some advantages over SDS, in the same way SDS has advantages over a key chuck. I often drill 5" holes through brick work or concrete, an SDS would not do the job,where as SDS is the one to use for drilling upto 30mm.
Ah but you only mentioned later in the thread you only wanted one around 2kg. The one I bought and my builder uses is 4/5kg and the equivalent Bosch are much more expensive.
I think for general diy the size you are looking at is ideal but for heavy duty drilling/chiselling/breaking the Titan is excellent value for money but a little cumbersome for smaller jobs.
and they are fugly :-)
