Okay.
I went shopping today. Firstly to Currys where I tried the Pentax K-x and the Canon EOS 1000 DC.
The lady in there knew nothing about cameras! So I was left to play around with them, not having a clue what I was doing!
The Pentax was heavier, but that didn't bother me because it wasn't "heavy". It comes with a 18-55mm lens and a 50-200mm lens.
The Canon was lighter, but we could not find a way of getting the image onto the monitor. Is that something that Canon's don't do, or was it just me being stupid!? That one comes with an 18-55mm EF-S Zoom lens. What does the "EF-S" mean?
So out of the 2 I tried there, I preferred the Pentax. The deal that they have is very good, with 2 lenses and the body for £399.99
Are the lenses suitable for me?
Then I went to Jessops, where the assistant showed me some "Compact System Cameras"
She explained that they don't have the mirror system, so take the pictures quicker and that they are basically an easier SLR.
She showed me the Samsung NX5, which comes with:
•18-55mm Lens
•Samsung EX50-200mm f/4-5.6 OIS lens
•Samsung Premium Soft Case
•Velbon VTP-777 Tripod
With the whole bundle costing £449.
It also has an amazingly quick "burst" mode which was 30 fps!!! Obviously very good for what I want to do!
So I am now in a dilemma.
Which camera has the best lenses?
Here are the links:
Samsung NX5:
http://www.jessops.com/online.store/products/79396/show.html
Pentax K-x:
http://www.currys.co.uk/gbuk/pentax...oom-lens-50-200mm-zoom-lens-03858320-pdt.html
Canon EOS 1000 DC:
http://www.currys.co.uk/gbuk/eos-10...5-mm-ef-s-zoom-lens-10-1-mp-02441727-pdt.html
On paper, the Pentax sounds the best, with 12.4 mp and 4.7fps.
But please can I have peoples advice?
Thank you
Hi Emma-Jane,
This is certainly a dilemma. As a matter of interest do you live near any "proper" camera shops because I find both Jessops and Currys generally useless if you need advice and not always very competitive on price. For instance I think this bundle from
Park cameras is quite a bit more useful from your POV as it includes a 70-300mm lens...
http://www.parkcameras.com/14935/Canon-EOS-1000D---18-55mm--non-IS----75-300mm-Lens.html
Also, it's relatively common to find camera gear faulty in some way and a decent dealer (even a reputable mail order one) will generally be more supportive if you need to exchange or get a refund.
I used a Pentax system for many years, and they are great little cameras. They certainly do NOT feel cheap and plasticky for the money when compared to the equivalent priced competition. The Kx bundle you mentioned was very good value. It also has image stabilisation built in to the body and will work with any lens Pentax ever made, which means good
second hand bargains if you can find any.
The downside though, and its a big one, is that prior to the K5 (which seems to be much improved) Pentax bodies were not all that good at tracking moving objects. I seldom did this so it never bothered me, but if you want to shoot outdoor sports I would probably tend towards the Canon or Nikon choices.
What I would NOT do is buy any of the mirrorless cameras because they are nowhere near as good as any SLRs for movement tracking and the systems are nowhere near as expandable. The 30fps is also misleading, its only at very low resolution! Don't go there, trust me. Maybe they will sort the tracking technology out in a few years....
I also had a lot of frustration with quality control on a Pentax K7 so I would not even consider buying a
second hand one. My dealer was fantastic and helped me sort it out and I don't think new ones would be an issue, but I don't trust second hand camera equipment unless I can test it very thoroughly first, which again means getting it through a reputable dealer with a warranty. Be very careful!
So what to buy eh? Well all SLR systems will support basic manual operation as well as A, P and S modes, so you can learn photography with any of them. However, each level you go up, the better the performance and quality generally gets.
If you stick with Nikon and Canon, the main thing to remember is that Canons only make lenses with motors in them (EF and EF-S - the latter for APSC format cameras only). All current Canon lenses will work with their entry level bodies.
Nikon still make some screw drive lenses (AF-D) which won't autofocus with lower end bodies. Its really not a huge deal unless you want to scour for second hand bargains or you really love older prime lenses, but some third party lenses won't work either.
So, what are the best bundles you can get for your needs?
Cheapest options are the Canon EOS1000D (see above) or if you can still find one in stock, the discontinued D3000 which you could get a similar deal on.
These cameras are OK , basic but decent in terms of image quality. The main advantage of the Nikon is the 3D 11 point AF which is a lot more advanced than the Canon version.
The Nikon D3100 is a much newer camera with better IQ and more resolution (14MP). This is not a bad deal..
http://www.parkcameras.com/16530/Nikon-D3100---AF-S-DX-NIKKOR-18-55mm-VR.html
Or with 2 lenses
http://www.parkcameras.com/Bundle.aspx?BundleID=9702&display=true
Note the £40 cashback. The lenses have stabilisation too, unlike the Canon above.
You could go for the next model up (the D5000) with this bundle:
http://www.parkcameras.com/14158/Nikon-D5000---18-55mm---55-200mm-VR-Kit.html
You lose a bit of resolution and video resolution, but gain more frames per second and an articulated screen. The body has a few more features as well.
The next Canon model however is also very good. The EOS550D is a best seller, but its more expensive again. With only one lens the best kit is as follows.
http://www.parkcameras.com/14789/Canon-EOS-550D---EF-S-18-55mm-f-3-5-5-6-IS.html
To me the "Goldilocks" camera is the Nikon (well either Nikon). Not too basic, not too advanced, not too expensive, not too cheap. £600 is good value for what you are getting.
Please note, in 30 years I have used and loved Canons, Nikons, Minoltas (now Sony) and Pentaxes, and don't have any brand preference. All have pros and cons. However, there is always a model of lens or body or some combination that fits your needs best if you are objective in your choice. I would not turn down any camera if I wanted a good general purpose tool. They are all good nowadays. But when you know what you need and set a budget you can narrow the choices down very quickly.
