Need help with ideas for exams
Plemka
Hello , I have a couple of months until entrance exams to university and I need to do some "homework" . But i don't have any ideas what to do and how , so I ask for your help :)
Task:
The task is checking student's visual and technical thinking.
Requirements:
 It is 10-15 (minimum 10 , maximum 15) set.
 Required feature sketch involving two players.
 The action must take place in the exterior ( in the yard, park, forest, sports court ... )
 The plot should be simple and easy to use - without explanation and without literary dialogues described .
 Each photo should reflect a mounting frame narrative history .
 taken photos entrant must choose the angles , size, stand composition.
 Frame assembles the sequence to tell a story and photograph posed to meet the highest possible artistic and technical criteria.
 Photos can be photographed classic and digitally.
 Photos can be color or black and white .
I would be really thankful if you would help to me :)
Task:
Requirements:
Correct me if I'm wrong but isn't that the idea of 'homework'. You do it, not us?:cool:
I have to agree with the above. It's been assigned to you to do in order to TEST you. You do it. YOU research. YOU figure it out. What you are doing is tantamount to cheating. You're not researching anything, you're asking the question, and expecting other people to provide the answers.
If you can't step up and produce the required results, you don't deserve a place on the course, and yes... this is from me as a photography lecturer and curriculum manager at a higher education college. If I ever learned that someone I'd set an entrance exam for had just posted the problem to others online in order to get others to do the work for them, I'd definitely NOT be offering you a place.
Do the work you've been set... yourself, using YOUR ideas.
Having said that, someone without any sense of honour or decency will no doubt be along to "help" you shortly... so don't worry.
Yeah, I understand that I must to do this and I'm not asking you to do all work for me. I'm just asking you to help generate a simple idea, what could happen in this story, not the whole story. Sorry for misleading request.
Joining online forums (I see your first post on AP forums is the same as here) to ask people for ideas probably isn't the best way to go about it. They want to see how creative you are. You have a few months, put a bit of thought in and you will come up with plenty of ideas. :thumbs:
That's part of what you're being examined for. Photography is about ideas and creativity.
So how about re-phrasing it better? Because, quite frankly, your opening post doesn't make a whole lot of sense.
(and saying "Hi" and introducing yourself before launching into a complex request for homework help might be useful in persuading people you're not just here to scrounge some free help before you b****r off without so much as "Thank you" - but you've probably already lost that opportunity with most people that have already read this thread and the one on AP)
:agree:
I don't know, the "Youff" of today. Not even clever enough to cheet properly, aint they ayyy?
The requirements already tell you exactly what to do.
If you can't work that out then I agree with Pookeyhead.
