Need help on choosing a scanner
ujjwaldey8165
Ujjwal
Hi all. I need some suggestions here
I am new to medium format and B/W medium; and the only way to learn is to shoot, shoot and shoot more. So,
I am going to start doing a whole lot of medium format B/W photography; and cost is an obvious issue.
The 3 key cost components; and my solution to it are
Film : I am going to use Chinese films to keep cost down.
Development : Initially I am going to get them developed in Labs; but I am also going to try developing at home
Prints : I would print from Jessops etc, and this is expensive; and I dont need to print every frame; since many would be bad composition/ exposure etc. So my solution is that I would scan the negatives into comp, see the results and print only the ones I like from Jessops etc( which would initially be 30% - 50%, thereby cutting down costs).
So what I need is a cheap and cheerful scanner, which would scan the negatives (35mm, 4.5X6, 6X6 and 6X9) and at the touch of a button convert them into positives. This is really to tell me which negatives I should send for a proper print.
I dont need the highest qualilty scan, an average scan would do. And a slow scanner would do fine The key requirements are (i) low cost and (ii) ease of use
I definitely won't do any photoshop ( I dont see the point enhancing a photograph by computer programs; my personal view); and dont want to learn a whole lot of complex computer program. I would rather learn to use the camera better instead.
So what scanners would suit my purpose. To keep costs down I would look for a pre owner scanner.
Regards
Ujjwal
The Epson 4490 would be a good bet for you I reckon.
Buy the best film you can afford, or the best film for the intended subject. Don't walk into it thinking you'll shoot 20 rolls a day because that's unlikely, a decent roll of b/w is like £2.50, shooting 5 a week will produce more material than you'll have time to assess.
Regards
Ujjwal
The scanner software will want to make adjustments so the neg will look like it would if it had been printed, a straight "as you see it" scan of a b/w neg isn't exactly....inspiring.
So you'll need to know a little about curves/histograms and basic edit tools to get the best out of it. :)
Absolutely! Even if you were to print the negs conventionally, you'd have to select grade of paper and exposure time on the enlarger baseboard as a basic minimum of darkroom work, (or someone else would do it for you if you sent the negs for processing) so a few levels adjustments on your computer isn't any different at all.
