Janice
- Janice
Right, I have asked this question before but have not had an answer that explains. Maybe now we have some new members someone might be able to put this down so I can understand.
Or maybe its that Im not wording my question well......I will try harder.
I use manual mode on my camera all the time, along with spot metering. I tend to go on a loose idea of the Zone System... making sure my highlights in the clouds for instance arent blown out.. by metering off those and setting them at about +1.5. Or something dark would be spot metered and set at -1.5 (just examples)
Now.......................... If someone is using manual.... and uses matrix/evaluative metering which has loads of points.... this zone system method cant be done can it, because you cant say "I am metering off the white cloud" because it has loads of metering points all over the place on lots of different tones so you cant set anything as +1.5 for whites for example. Wouldnt they have to always set it in the centre and therefore defeat the object of being on manual?
So on the other side of the coin, if someone is using matrix metering, what is the point of using manual?
Wouldnt they be best using one of the automaticy type things like AP, or TV.
Answers on a postcard please
