Mongwopman
- Damien
Got it, thanks Dan.
Here earlier where I gave a full explanation of ambient vs flash and they're 2 different exposures!No, I was not going to use Exp.Compensation, however when looking through the view finder, and pressing the shutter half down, it indicates that little arrow to be off the left hand side of the scale. I thought that gave an indication as to the how far off the exposure is, Im guessing that it's reading the ambient light and that I can zero/centre it by changing the shutter?
Firstly if you're using Flash - forget AV. When you're shooting with flash you need to be aware of 2 exposures.
The ambient exposure - which may be a a stop above the flash exposure for daylit shots (flash as fill light), or a stop under for inside shots to give some atmosphere - or completely underexposed so as not to interfere - as with studio portraits. Outside - you could use AV, but generally I'd advise M for balancing flash. All of the above guides can be adjusted to taste.
The flash exposure requires you to have a shutter speed low enough for the camera to see all of the flash - typically between 1/100 and 1/200* but as long as it's less than that by not too much you're fine.
....more on the original post, if you need it.
Ok, well when I meter for the ambient it says it's WAY under exposed like off the scale, so if i bump the shutter speed up it only comes right when I am in like 2 or 3 second shutter speeds.
I'll have a double check tonight and play around but thats what i was getting last night.
Wonder if i shouldnt just go and get a fully compatable flash.
I'm no landscape expert, and I'm not really familiar with flash being used in landscape photography, with the exception of light painting, does that even count as landscape photography? I have no idea!I guess my venture into flash is because I want to branch out and not focus on only doing landscapes and also photograph people, and I had always thought that shooting people = flash important. I can see that I was wrong and that one does not always need flash, however saying that, using flash fill could also come in handy in certain scenarios when shooting landscapes.
At the moment my portraits are outdoors and not studio work. I dont have any equipment for studio work although will be investing in the near future. So getting to grips with flash or at least a little understand was/is my goal for now.
I'd have to see some of your work to help with that, all photography can be improved by improving the quality of light. As always, it's about what you want to achieve.At the moment my portraits just dont seem to "work" for me, flat, not sharp as I like, and lacking. I had read that by using flash one could produce images with more pop and also better sharpness, perhaps I was mislead?
I wouldn't go for the Yongnuo, because it's not 100% compatible, perhaps a Nissin or a 550ex? More expensive though.I feel that perhaps my flash outfit currently is not up to scratch as it does not even feature high speed sync.
So with that in mind I am going to flog it off and get something a little more updated, which leads me to my next question :
Do I go for a Canon brand ie the 430EX II or do is it ok to go for the Yongnuo YN560 II which is a quarter of the price?
Thanks for your patience and advice, It is really appreciated.
Danzaroonie said:This might assist you with basics...
http://www.adorama.com/alc/0012821/article/On-Camera-Flash-Basics-AdoramaTV
Rule of Thumb for flash...
Aperture controls amount of light from the flash... (higher the aperture number more light from the flash required)
Shutter speed controls the ambient light..(slower the shutter more ambient light)
The above applies for indoors and out, thou depending on how sunny it is you need to use High-speed sync for high shutter speeds.(review this later get the basics down first)
This wrong. Aperture controls both ambient and flash.
The only strict truth is that shutter speed does not effect flash exposure, but everything else effects everything else!
And although Manual flash can be difficult, ETTL has its faults too, sometimes we go to manual flash to overcome these issues.
Sorry it's not straightforward.
But it's plainly the wrong info and easy to prove so. Every photographer understands that opening or closing the aperture lets in more or less light so once you explain that there are two exposures going on and how each works it's relatively easy to learn the basics without having to relearn all over again.
- Mr Bryan Peterson ….)I total agree when your not using a manual power source to light the subject, but in this case even when you change the aperture you should balancing the power of flash to still keep the subject lit.....thats what I have been made to believe (now Im doubting the info I have read- Mr Bryan Peterson .)
The nissin di866 is similar in spec to the 580ex, costing a similar price to a s/h 550 or less than a 430ex.Any particular model nissin? 550ex is out of my budget range at the moment. So it would have to be 430ex II or an equivalent model in Nissin.
I've read how ETTL can cause some issues and not expose properly.
Done as you have said phil and the images come out....BLACK! Set a bottle up on a wooden table and entered settings as you stated. Stood opposite end of the room and black, continued working forward and all remains black.
Just dont understand it! When I go back to Av mode on the cam, flash fires but just looks like normal ambient light. Even if I + or - the FEB.
Nope, even after dowble checking, The flash is massively underexposed.
Been through all the settings on the flash and the only thing I can find which relates to master is the in the wireless section, which I am not using.
There is a sub-flash option but that is set to off. Even if on, it's the same.
Pulling my hair out here!
