Mamiya 645 focus issue?
I can see what you are getting at with photos you have posted. You are trying for a big depth of field with the foreground and the far distance in focus.
The thing is you can never really rely on the DOF scales on the lens and I appreciate that you can see that it appears fine in the view finder but if you were using a prism on the Pro then I find them difficult make a proper judgement of focus across the frame.
My own system is to use a WLF when DOF is critical as they have a nice magnifier built in which lets me get a good idea of what is going on. I also always give the scale on the lens at least an extra F stop when looking for a large DOF and even when stopping down to see the effect it is not always 100% correct in my experience.
I think you will find there is nothing wrong with your gear and the more you use it the better you will get.
Good advice thanks. Think it's just the idiot behind the lens.
The online DoFMaster (http://www.dofmaster.com/dofjs.html) suggests 1.8m to 7m DoF for 6x4.5/45mm/f11/2.75m with a 0.045 circle of confusion.
Given that, I'm not sure there's a problem at all, except maybe on the lens markings. The stuff in the foreground is sharp, infinity isn't.
Thanks for the link. Begins to strengthen what I thought about human error.
Do you wear spectacles?
As a subject we have never discussed here is:- if you need different ones for different seeing distances (esp when old) can they make a difference when focussing......you'd think I would know being old but sometimes when doing close up shots I can get the subject that I think is sharp, but the results show different and it's something sharp in front or behind (of course it could be the idiot behind the camera :D). One day I'll sort through my many spectacles and use one that I think is best for my cameras.
Yes this is an interesting one. I have recently acquired a couple of old Nikon Cameras namely a FM and an FE and found that nothing was clear through the view finder. After much research I found that these cameras had the view finder set to -1 Diopter and to get a clear view I ned a 0 diopter Nikon adjustment lens top correct the problem. Additional the Nikon 0 diopter lens is in fact +1 diopter although marked 0 dipoter. So adding the 0 dipoter ( +1) lens to the camera it brings the view finder to 0 diopter and I can see every thing clearly. Do not make things easy do they.....
Good question but no, no specs, might be worth me booking an appointment for peace of mind though!
Well everyone should have their eyes tested even if you don't need specs as they test for possible future problems e.g cataracts, glaucoma etc
Bit of an update:
Done the test shots, developed and scanned. It seems I am officially the weak link, as expected.
Shots at f11 are perfectly acceptable when focused at 5m.
Shots at f16 are good at 3m focal distance.
I will add some test shots when I get to my computer at the weekend but would just like to say thanks to all who have helped.
Good stuff Matt, always nice to solve a problem without having to send a camera away or spend money....I find that I am behind the majority of the problems I have......I wish you good shooting with it..
