Cagey75
- Keith
- No
Equivalence is about creating an "equivalent image" in all aspects, to include ISO noise. If you accept that the relative aperture to sensor size affects the resulting noise, then you must realize that the aperture has to be factored for equivalence... they are the same thing.
Yes, it matters... because it affects the results. For instance the 100-300 you mentioned delivers not more than ~ 6MP on a 21MP 4/3 sensor (E-M1 MkII), and it can only deliver that much at 100/5.6... it only gets worse from there. There are a lot of reasons for that which include sensor size (MTF), pixel size (diffraction), and ISO noise (discernible detail).
Does that really matter? That depends on what you actually need. Do you need to know that? No, probably not; as long as it is delivering at least as much as you need. Would I use such a combination? Yes, probably... I'm pretty certain my Nikon1 V2 with it's CX 70-300mm isn't a lot better. But would I use it professionally? Not a chance...
That 100-300 lens still gathers plenty enough light for even dimmer winter evenings as I said already. I'm also only using a 16mp sensor. I also don't tend to get hung up on DXOmark numbers. I've had lenses that they listed as not being very sharp really surprise me, and there's nowt wrong with my eyes, 20/20. Sometimes numbers just don't matter. I'm not a professional, so I don't need to worry too much on it.
