JonathanRyan
- Jonathan
I'm getting mixed up between lithium grease, PTFE spray and good old WD40.
I have 2 separate things I need to do. What products would you recommend for the following? (Preferably something I can just get from Screwfix etc)
1. Kitchen sliding cupboard type thing. It uses heavy duty drawers runners with ball bearings in but the weight in it might be quite a lot (it's a spice cupboard and it's kind of full). Need to degrease a jammed runner and then lube them to make them easier to slide.
2. CHEAP Ikea style drawers. The kind with plastic runners in the carcass and wooden grooves in the drawers so you have bare pine (?) running over plastic. They jam frequently leading to wear on the drawer fronts.
