Hello
A quick Question: When you choose delete from disk in lightroom does it or is it meant to delete it permanently from the hard drive??
Matt
It will usually move it to the trash. Unless it is on an external disk, then it may go straight away.
Delete from Disk moves the file to the recycle bin.
Remove just removes the file from Lightroom
Sounds like you have "removed" files from lightroom's catalogue, which means they are still sitting on your HDD, just that Lightroom is ignoring them. You need to delete from disk (which shifts them to trash which you can then empty).
Or . . Even deleted ones will show up as eaten hard drive space if still in the recycle bin.![]()
